48-482 no SW
FOUND IT! Another very hidden resistor on the push button switch deck 22k inside spagetti tubing under wires and caps w/ short leads. Replaced it and it sings like a bird on SW band.
I did a over the air alignment for AM and FM and IF's. I touched up the FM1000 coil /cap but returned to original positions. Sounds pretty good so why recreate the wheel. My Rider diagram is not real clear. Does anyone have a recomendation as to calibrating the SW Osc trimmers?
I may just leave it alone.
Dave Casazza
Keep em glowin and goin...
48-482 no SW - by DCASAZZA - 10-12-2009, 11:27 PM
Re: 48-482 no SW - by DCASAZZA - 10-17-2009, 10:16 PM
Re: 48-482 no SW - by exray - 10-17-2009, 11:14 PM
Re: 48-482 no SW - by DCASAZZA - 10-18-2009, 06:59 AM
Re: 48-482 no SW - by Sean - 10-18-2009, 10:50 AM
Re: 48-482 no SW - by DCASAZZA - 10-18-2009, 11:37 PM
RCA T62 is playing.....
Philco 91 Restore Code ??
Philco 40-120C Restoration
Philco 89 indicator light.
