Radio Mystery
Welcome to the Phorum!
Icon_wave
I can't answer your question but hopefully someone else might be able to.
update:  for what its worth, that control panel sure is similar (though not identical) to the  Philco CT-11 car radio that went into 1936 Chryslers (according to Ron's chart).  The link is to a current ebay item just for reference.  I would bet that the radio was an add-on and might not be a 1948 radio (just guessing though).
update#2:  the other item that seems to pop on 1947 International Truck up when you google around is Philco's UN6 100 radio which is not like your photo at all.
Radio Mystery - by tomco1122 - 12-07-2016, 09:49 PM
RE: Radio Mystery - by klondike98 - 12-07-2016, 10:11 PM
RE: Radio Mystery - by tomco1122 - 12-08-2016, 11:42 AM
RE: Radio Mystery - by Arran - 12-16-2016, 12:11 AM
RE: Radio Mystery - by tomco1122 - 02-09-2017, 01:07 PM
RE: Radio Mystery - by Radioroslyn - 02-12-2017, 11:18 AM
