Picking up a 37-690
Greg
From the experience of transporting a 38-690 from MD to NJ.
I did not disconnect speakers, no should you unless removing chassis requires that (doubt it, all speakers are likely connectorized).
I pulled out main chassis only, left the lower amp/power unit chassis inside.
The transporting in my Jeep GC went just fine.
PS. Make sure the speakers are held like they should be, securely, no loose bolts.
PPS. If the cabinet is to be refinished, it is not important if you put it face down. If it is not, put some soft clean blankets under the radio. This way speaker has no way of detaching and falling.
PPS. You will need screwdrivers for disassembly; I do not remember anything else needed.
Picking up a 37-690 - by Greg - 12-08-2016, 12:27 AM
RE: Picking up a 37-690 - by Ron Ramirez - 12-08-2016, 07:10 AM
RE: Picking up a 37-690 - by morzh - 12-08-2016, 10:49 AM
RE: Picking up a 37-690 - by Greg - 12-09-2016, 09:54 PM
RE: Picking up a 37-690 - by Philcophan - 12-23-2016, 12:23 PM
New member
Hello jeff, Welcome aboard ! Sincerely Riochardradiorich — 06:53 PM
New member
Good picture, When was it taken? You don't look in it like a guy who has a teenage son :)morzh — 06:13 PM
New member
Philco 630csx power cord
New member
