Philco 19X restoration
I was about to say the same: Philco used Philco-marked caps, so instead of interpreting the code of a cap that might even not be of the same value it was intended to replace, just see what backelite (or other) cap it is parallelled to, find it on the sch and follow with restuffing the backelite cap with the appropriate value new part.
Philco 19X restoration - by yossarian1988 - 12-08-2016, 09:55 AM
RE: Philco 19X restoration - by klondike98 - 12-08-2016, 11:52 AM
RE: Philco 19X restoration - by morzh - 12-08-2016, 12:30 PM
RE: Philco 19X restoration - by Radioroslyn - 12-08-2016, 12:47 PM
RE: Philco 19X restoration - by yossarian1988 - 12-08-2016, 02:25 PM
RE: Philco 19X restoration - by Radioroslyn - 12-09-2016, 12:17 PM
RE: Philco 19X restoration - by morzh - 12-08-2016, 03:31 PM
RE: Philco 19X restoration - by Radioroslyn - 12-08-2016, 07:28 PM
RCA T62 is playing.....
Philco 91 Restore Code ??
Philco 40-120C Restoration
Philco 89 indicator light.
There are currently 8698 online users. [Complete List]
» 3 Member(s) | 8695 Guest(s)
