Philco 19X restoration
Oh yeah....this is the only 90nF cap sold by Mouser.
http://www.mouser.com/ProductDetail/Keme...fh4g%3d%3d
Surprisingly, not expensive.
But very poorly suited for backelite stuffing.
Philco 19X restoration - by yossarian1988 - 12-08-2016, 09:55 AM
RE: Philco 19X restoration - by klondike98 - 12-08-2016, 11:52 AM
RE: Philco 19X restoration - by morzh - 12-08-2016, 12:30 PM
RE: Philco 19X restoration - by Radioroslyn - 12-08-2016, 12:47 PM
RE: Philco 19X restoration - by yossarian1988 - 12-08-2016, 02:25 PM
RE: Philco 19X restoration - by Radioroslyn - 12-09-2016, 12:17 PM
RE: Philco 19X restoration - by morzh - 12-08-2016, 03:31 PM
RE: Philco 19X restoration - by Radioroslyn - 12-08-2016, 07:28 PM
RCA T62 is playing.....
Philco 91 Restore Code ??
Philco 40-120C Restoration
Philco 89 indicator light.
There are currently 7123 online users. [Complete List]
» 3 Member(s) | 7120 Guest(s)
