#66
I think there is a disconnect. I was just saying the the resistance from pin 7 was measured to be 0.6 Ohms with the radio powered off. Then I was following the line from the pin on the schematic and was thinking that the resistance is written as "less 1 ohm" or possibly it says "less 0.1 Ohm" there.
But I did have a laugh at "Now you know that's not right"
42-365 - by ccbaker13 - 11-23-2016, 04:11 PM
RE: 42-365 - by morzh - 11-23-2016, 04:52 PM
RE: 42-365 - by ccbaker13 - 11-23-2016, 05:09 PM
RE: 42-365 - by morzh - 11-23-2016, 05:24 PM
RE: 42-365 - by ccbaker13 - 11-23-2016, 06:01 PM
RE: 42-365 - by morzh - 11-23-2016, 06:44 PM
RE: 42-365 - by Radioroslyn - 11-23-2016, 09:17 PM
RE: 42-365 - by ccbaker13 - 11-23-2016, 09:39 PM
RE: 42-365 - by Steve Davis - 11-23-2016, 10:50 PM
RE: 42-365 - by ccbaker13 - 11-23-2016, 11:49 PM
RE: 42-365 - by ccbaker13 - 11-24-2016, 12:09 AM
RE: 42-365 - by ccbaker13 - 11-24-2016, 12:15 AM
RE: 42-365 - by ccbaker13 - 11-24-2016, 12:36 AM
RE: 42-365 - by Radioroslyn - 11-24-2016, 08:59 AM
RE: 42-365 - by ccbaker13 - 11-24-2016, 09:30 AM
RE: 42-365 - by Steve Davis - 11-25-2016, 11:33 AM
RE: 42-365 - by ccbaker13 - 11-25-2016, 11:54 AM
RE: 42-365 - by ccbaker13 - 12-01-2016, 09:09 PM
RE: 42-365 - by Radioroslyn - 12-02-2016, 01:28 AM
RE: 42-365 - by ccbaker13 - 12-02-2016, 07:26 AM
RE: 42-365 - by Radioroslyn - 12-02-2016, 08:11 AM
RE: 42-365 - by ccbaker13 - 12-02-2016, 08:43 AM
RE: 42-365 - by Radioroslyn - 12-02-2016, 09:21 AM
RE: 42-365 - by ccbaker13 - 12-02-2016, 09:33 AM
RE: 42-365 - by Radioroslyn - 12-02-2016, 03:33 PM
RE: 42-365 - by ccbaker13 - 12-02-2016, 08:52 PM
RE: 42-365 - by Radioroslyn - 12-02-2016, 09:28 PM
RE: 42-365 - by ccbaker13 - 12-03-2016, 06:39 PM
RE: 42-365 - by Radioroslyn - 12-03-2016, 07:08 PM
RE: 42-365 - by ccbaker13 - 12-03-2016, 07:50 PM
RE: 42-365 - by Radioroslyn - 12-03-2016, 08:30 PM
RE: 42-365 - by ccbaker13 - 12-03-2016, 08:47 PM
RE: 42-365 - by klondike98 - 12-03-2016, 09:54 PM
RE: 42-365 - by Radioroslyn - 12-03-2016, 10:41 PM
RE: 42-365 - by ccbaker13 - 12-03-2016, 10:47 PM
RE: 42-365 - by ccbaker13 - 12-06-2016, 07:06 PM
RE: 42-365 - by Radioroslyn - 12-06-2016, 08:39 PM
RE: 42-365 - by ccbaker13 - 12-06-2016, 09:22 PM
RE: 42-365 - by ccbaker13 - 12-06-2016, 09:23 PM
RE: 42-365 - by Radioroslyn - 12-06-2016, 11:10 PM
RE: 42-365 - by KCMike - 12-06-2016, 10:08 PM
RE: 42-365 - by ccbaker13 - 12-06-2016, 10:28 PM
RE: 42-365 - by Radioroslyn - 12-06-2016, 11:06 PM
RE: 42-365 - by ccbaker13 - 12-06-2016, 11:10 PM
RE: 42-365 - by ccbaker13 - 12-06-2016, 11:12 PM
RE: 42-365 - by ccbaker13 - 12-06-2016, 11:14 PM
RE: 42-365 - by ccbaker13 - 12-06-2016, 11:24 PM
RE: 42-365 - by Radioroslyn - 12-07-2016, 12:42 AM
RE: 42-365 - by ccbaker13 - 12-07-2016, 08:29 PM
RE: 42-365 - by ccbaker13 - 12-07-2016, 08:34 PM
RE: 42-365 - by Radioroslyn - 12-07-2016, 09:15 PM
RE: 42-365 - by ccbaker13 - 12-07-2016, 09:47 PM
RE: 42-365 - by ccbaker13 - 12-07-2016, 09:51 PM
RE: 42-365 - by ccbaker13 - 12-07-2016, 10:07 PM
RE: 42-365 - by Radioroslyn - 12-07-2016, 10:47 PM
RE: 42-365 - by ccbaker13 - 12-07-2016, 11:08 PM
RE: 42-365 - by Radioroslyn - 12-07-2016, 11:44 PM
RE: 42-365 - by ccbaker13 - 12-08-2016, 07:31 PM
RE: 42-365 - by Radioroslyn - 12-08-2016, 11:51 PM
RE: 42-365 - by Radioroslyn - 12-08-2016, 08:05 PM
RE: 42-365 - by ccbaker13 - 12-08-2016, 08:18 PM
RE: 42-365 - by sam - 12-08-2016, 08:23 PM
RE: 42-365 - by ccbaker13 - 12-08-2016, 09:28 PM
RE: 42-365 - by ccbaker13 - 12-08-2016, 09:30 PM
RE: 42-365 - by morzh - 12-08-2016, 09:37 PM
RE: 42-365 - by ccbaker13 - 12-08-2016, 09:55 PM
RE: 42-365 - by Radioroslyn - 12-08-2016, 10:08 PM
RE: 42-365 - by ccbaker13 - 12-08-2016, 10:17 PM
RE: 42-365 - by ccbaker13 - 12-08-2016, 10:19 PM
RE: 42-365 - by ccbaker13 - 12-08-2016, 10:23 PM
RE: 42-365 - by Radioroslyn - 12-08-2016, 10:29 PM
RE: 42-365 - by ccbaker13 - 12-08-2016, 10:57 PM
RE: 42-365 - by ccbaker13 - 12-08-2016, 10:59 PM
RE: 42-365 - by morzh - 12-08-2016, 11:05 PM
RE: 42-365 - by ccbaker13 - 12-08-2016, 11:12 PM
RE: 42-365 - by ccbaker13 - 12-09-2016, 09:03 AM
RE: 42-365 - by ccbaker13 - 12-09-2016, 09:06 AM
RE: 42-365 - by ccbaker13 - 12-09-2016, 09:19 AM
RE: 42-365 - by ccbaker13 - 12-09-2016, 09:20 AM
RE: 42-365 - by Radioroslyn - 12-09-2016, 10:16 AM
RE: 42-365 - by ccbaker13 - 12-09-2016, 11:02 AM
RE: 42-365 - by Radioroslyn - 12-09-2016, 11:58 AM
RE: 42-365 - by ccbaker13 - 12-09-2016, 12:40 PM
RE: 42-365 - by ccbaker13 - 12-09-2016, 10:19 PM
RE: 42-365 - by ccbaker13 - 12-10-2016, 03:24 PM
RCA T62 is playing.....
Philco 91 Restore Code ??
Philco 40-120C Restoration
Philco 89 indicator light.
There are currently 3750 online users. [Complete List]
» 3 Member(s) | 3747 Guest(s)
