Hickok 600A tube tester
I believe I did "check" the calibration, but I didn't change anything. It was pretty close. I don't recall for sure the details. One of these days I may get brave and try to clean the air gap in my meter, but it does work, so I am gonna leave it that way for now. Mine had diodes soldered in place to replace the 83. I was concerned, but ended up leaving it alone.
Tim
Hickok 600A tube tester - by vecher - 12-03-2016, 01:32 AM
RE: Hickok 600A tube tester - by morzh - 12-03-2016, 10:31 AM
RE: Hickok 600A tube tester - by John R - 12-03-2016, 02:29 PM
RE: Hickok 600A tube tester - by vecher - 12-03-2016, 02:49 PM
RE: Hickok 600A tube tester - by Phlogiston - 12-03-2016, 04:19 PM
RE: Hickok 600A tube tester - by vecher - 12-03-2016, 04:30 PM
RE: Hickok 600A tube tester - by morzh - 12-03-2016, 05:29 PM
RE: Hickok 600A tube tester - by vecher - 12-03-2016, 06:38 PM
RE: Hickok 600A tube tester - by vecher - 12-03-2016, 10:58 PM
RE: Hickok 600A tube tester - by vecher - 12-04-2016, 12:05 AM
RE: Hickok 600A tube tester - by morzh - 12-04-2016, 12:45 PM
RE: Hickok 600A tube tester - by Radioroslyn - 12-04-2016, 03:36 PM
RE: Hickok 600A tube tester - by morzh - 12-04-2016, 04:07 PM
RE: Hickok 600A tube tester - by vecher - 12-04-2016, 04:45 PM
RE: Hickok 600A tube tester - by morzh - 12-04-2016, 05:40 PM
RE: Hickok 600A tube tester - by vecher - 12-04-2016, 06:03 PM
RE: Hickok 600A tube tester - by vecher - 12-05-2016, 12:02 PM
RE: Hickok 600A tube tester - by morzh - 12-05-2016, 08:32 PM
RE: Hickok 600A tube tester - by vecher - 12-05-2016, 10:05 PM
RE: Hickok 600A tube tester - by TV MAN - 12-09-2016, 02:05 PM
RE: Hickok 600A tube tester - by vecher - 12-09-2016, 04:29 PM
RE: Hickok 600A tube tester - by TV MAN - 12-09-2016, 09:52 PM
