Thinking about buying model 630 Console?
(03-23-2016, 11:22 AM)philconerd Wrote:  **
Okay, so I did buy the 630 console yesterday.  I have less than $ 20 invested in this thing.  And the best part is no shipping damage to it because I drove over and picked it up!
I'm not sure when I will start into this one so it may sit in the garage for a couple months until then.  At the very least there are a lot of good parts in it.  All of the parts seem to be there, even the shadow meter.
G.
It Works!
This console sat all Summer and Fall until this week when I started to look at it.  So far Iv'e replaced the 4 electrolytic caps, cleaned the bandswitch and tested the tubes.  Today with a dim bulb tester, I slowly tested out the chassis and found everything seems to be working pretty well for an old 1936 console.
I know I will have to replace more capacitors and resistors to get it tuned up and working well and this will be done over the next few weeks.
I will post more information a about the progress.
G.
I bought the model 630 Console. - by philconerd - 03-23-2016, 11:22 AM
RE: Thinking about buying model 630 Console? - by philconerd - 12-09-2016, 09:57 PM
RCA T62 is playing.....
Philco 91 Restore Code ??
Philco 40-120C Restoration
Philco 89 indicator light.
There are currently 6152 online users. [Complete List]
» 1 Member(s) | 6151 Guest(s)
