New to the forum. Hi all. questions about a 38-60
Thanks for the advise guys. I am new to radios but I can use a soldering iron and will do much reading before starting to do the recap myself. The radio by the way is a table model tombstone and it looked like it had never had a back on it. I have been listening to it already for a few hours at a time with no problems but will take your advise and rebuild it so that I know that it has been done. When you say that the squelching noise could be made by a dirty control how do you go about cleaning that? if there is a section that describes this if you could just point me in the right direction I would appreciate it. Thanks again for all the info!! Shawn
New to the forum. Hi all. questions about a 38-60 - by Guest - 10-21-2009, 04:11 PM
Re: New to the forum. Hi all. questions about a 38-60 - by Guest - 10-25-2009, 12:31 PM
Philco 630csx power cord
Model 27-84 BUZZ?Humm?
There are currently 1675 online users. [Complete List]
» 1 Member(s) | 1674 Guest(s)
