Philco 41-221 Questions
you can "wet" it up real good,,,in order to remove it,,if that is what you want to do,,,,to make you feel SAFE,,put it isn a sandwich bag,,,and in the trash,,,or do what they did with the trains from New York,,,which was Loaded with it,,,,,they dump them in the ocean for the fish to live in,,,,which now are completely rotted apart,, and caved in now
Philco 41-221 Questions - by Nick3092 - 03-04-2014, 11:22 AM
RE: Philco 41-221 Questions - by TA Forbes - 03-04-2014, 01:18 PM
RE: Philco 41-221 Questions - by Eliot Ness - 03-04-2014, 03:31 PM
RE: Philco 41-221 Questions - by Nick3092 - 03-04-2014, 07:02 PM
RE: Philco 41-221 Questions - by morzh - 03-04-2014, 07:32 PM
RE: Philco 41-221 Questions - by Nick3092 - 03-04-2014, 08:36 PM
RE: Philco 41-221 Questions - by Raleigh - 03-09-2014, 03:33 PM
RE: Philco 41-221 Questions - by 462ron - 03-09-2014, 07:50 PM
RE: Philco 41-221 Questions - by Sinatra1982 - 12-10-2016, 11:49 PM
RE: Philco 41-221 Questions - by Kenneth F. Besso Jr. - 12-11-2016, 10:01 AM
RCA T62 is playing.....
Philco 91 Restore Code ??
Philco 40-120C Restoration
Philco 89 indicator light.
There are currently 3806 online users. [Complete List]
» 3 Member(s) | 3803 Guest(s)
