My little PT-93 is finished
(12-11-2016, 02:53 AM)Sinatra1982 Wrote:  How do you make the dial lens with the mold?
http://www.firebottleradio.com/make-a-lens.html
My little PT-93 is finished - by OldRestorer - 10-02-2015, 11:05 AM
RE: My little PT-93 is finished - by sam - 10-02-2015, 11:41 AM
RE: My little PT-93 is finished - by OldRestorer - 10-02-2015, 02:04 PM
RE: My little PT-93 is finished - by Radioroslyn - 12-11-2016, 08:14 PM
RE: My little PT-93 is finished - by Eliot Ness - 10-02-2015, 04:19 PM
RE: My little PT-93 is finished - by mikethedruid - 10-02-2015, 04:26 PM
RE: My little PT-93 is finished - by OldRestorer - 10-02-2015, 05:10 PM
RE: My little PT-93 is finished - by Radioroslyn - 10-02-2015, 05:40 PM
RE: My little PT-93 is finished - by Sinatra1982 - 12-11-2016, 02:53 AM
RE: My little PT-93 is finished - by Radioroslyn - 12-11-2016, 08:17 PM
RE: My little PT-93 is finished - by OldRestorer - 12-12-2016, 10:14 AM
RE: My little PT-93 is finished - by PhilcoJohn - 12-12-2016, 07:41 PM
RE: My little PT-93 is finished - by OldRestorer - 12-12-2016, 08:59 PM
RCA T62 is playing.....
Philco 91 Restore Code ??
Philco 40-120C Restoration
Philco 89 indicator light.
