paper wax caps
I have two questions about paper caps.  First, I have a paper wax cap that has a ground arrow pointing to a lead.
Does not these type caps have a pos or neg side?   And I have a cap that says.0033 mfd,  1600 VDC.  Do they make a cap with that much voltage and if so where can I get one.  Thanks...
paper wax caps - by Sinatra1982 - 12-11-2016, 10:50 PM
RE: paper wax caps - by Radioroslyn - 12-12-2016, 12:56 AM
RE: paper wax caps - by Sinatra1982 - 12-12-2016, 02:57 AM
RE: paper wax caps - by morzh - 12-12-2016, 08:46 AM
RE: paper wax caps - by 462ron - 12-12-2016, 03:30 PM
RE: paper wax caps - by Dennis Craft - 12-13-2016, 11:18 AM
RE: paper wax caps - by morzh - 12-13-2016, 06:41 PM
RE: paper wax caps - by klondike98 - 12-13-2016, 02:14 PM
RE: paper wax caps - by Sinatra1982 - 12-16-2016, 08:56 AM
RE: paper wax caps - by TV MAN - 12-16-2016, 11:52 AM
RE: paper wax caps - by doug-5er - 12-17-2016, 11:19 PM
RCA T62 is playing.....
Philco 91 Restore Code ??
Philco 40-120C Restoration
Philco 89 indicator light.
There are currently 6247 online users. [Complete List]
» 4 Member(s) | 6243 Guest(s)
AvatarAvatarAvatarAvatar
