How to make a new dial cover tutorial
Well....I still am willing to pay for Mark Palmquist's lenses vs DIM ones. At $20 shipped (I believe in Kutztown it was a bit less) for me it makes sense. He also makes glass ones. Plus the gaskets.
RE: New dial cover chronicles - by OldRestorer - 03-19-2014, 08:05 PM
RE: New dial cover chronicles - by OldRestorer - 03-19-2014, 08:07 PM
RE: New dial cover chronicles - by OldRestorer - 03-19-2014, 08:26 PM
RE: New dial cover chronicles - by hsusmann - 03-19-2014, 08:47 PM
RE: New dial cover chronicles - by morzh - 03-19-2014, 08:50 PM
RE: New dial cover chronicles - by skyscraper - 03-19-2014, 09:19 PM
RE: New dial cover chronicles - by OldRestorer - 03-19-2014, 09:52 PM
RE: New dial cover chronicles - by Warren - 03-20-2014, 12:07 AM
RE: New dial cover chronicles - by tab10672 - 03-20-2014, 12:54 AM
RE: New dial cover chronicles - by Warren - 03-20-2014, 02:13 AM
RE: How to make a new dial cover tutorial - by abes.cherif - 02-09-2015, 09:44 PM
RE: How to make a new dial cover tutorial - by morzh - 12-12-2016, 07:41 PM
Philco 91 Tuning Condenser
There are currently 6688 online users. [Complete List]
» 2 Member(s) | 6686 Guest(s)
