Philco 70 field coil
Weigh the wire and bobbin together, then weigh the wire alone. Spool the new wire on the bobbin until it reaches the weight of the combined items. Usually you're with 1 or 2% of the needed resistance at this point provided you're using the same guage wire.
Philco 70 field coil - by KCMike - 12-14-2016, 11:52 PM
RE: Philco 70 field coil - by Jim Koehler - 12-15-2016, 12:38 PM
RE: Philco 70 field coil - by KCMike - 12-15-2016, 04:39 PM
46-1201 Trip Switch Spring
So, Q1. Does anyone know where to get the spider. Q2. If there is no such place, what material is best? I doubt tin is...morzh — 09:43 PM
Arran The oxidation seems to go deep, a few layers. The break starts right there, but then it will occur on every la...morzh — 07:35 PM
