AM transmitter question with phone, pad, etc.
You will be better off using a suitable patch cord from your sources earphone jack to your transmitter input, which I think are RCA male jack connectors. I use an i-pod with my music library set on random play and let it go 24/7. I also the i-pod EQ to customize the output sound. By using your headphone jack, that mutes the sound on the phone and sends sound to/ through your transmitter. Enjoy.
New member
Philco 630csx power cord
New member
There are currently 3922 online users. [Complete List]
» 3 Member(s) | 3919 Guest(s)
