1932 Mystery Cathedral Radio Restore on YouTube
#34
(09-10-2016, 09:11 PM)Buzz Wrote:  Hi Elliot..Can you take some pics of it..any markings on the chassis or dial??..Buzz
Sorry Buzz, by the time I dug it out it wasn't as similar as I remembered it.  It is just like this one:
http://www.ebay.com/itm/rare-1931-KENNED...xy0bRTEyJi
Anyway, I  always enjoy your videos!
Edit:  I binge watched the last 9 shows in this series and I was very impressed.  You turned a radio most would have trashed into a beautiful set!
RE: 1932 Mystery Cathedral Radio Restore on YouTube - by Eliot Ness - 12-15-2016, 11:13 PM
RCA T62 is playing.....
Philco 91 Restore Code ??
Philco 40-120C Restoration
Philco 89 indicator light.
