6A3 replacements
I finally got my Philco 116X working, but with a borrowed pair of 6A3 output tubes. Reception and audio quality are outstanding.
Short of buying a working pair of 6A3s at current prices (thanks, audiofools) what might be recommended as replacements? 6B4G is electrically the same tube, octal base, same high prices.
Changing the tube sockets / types is heresy to many on the forum, but this set is no beauty queen. I'd like to enjoy the set as work bench company. All electronics would be completed neatly and to a high standard, as has the rest of the chassis.
I considered using a single 6AS7 with its two sections in push-pull, or a pair of triode connected 807s with operating voltages accordingly changed. Those types are already on hand, in storage. I believe those choices could approximate present current draw from the power transformer, audio output transformer impedances, and available audio power output.
All help is greatly appreciated!
Keep warm, this weekend.
-O.B.
6A3 replacements - by Old Buzzard - 12-16-2016, 08:05 PM
RE: 6A3 replacements - by KCMike - 12-16-2016, 09:23 PM
RE: 6A3 replacements - by morzh - 12-16-2016, 11:44 PM
RE: 6A3 replacements - by Ron Ramirez - 12-17-2016, 12:26 AM
RE: 6A3 replacements - by w4rtc - 12-17-2016, 11:09 AM
RCA T62 is playing.....
Philco 91 Restore Code ??
Philco 40-120C Restoration
Philco 89 indicator light.
There are currently 5876 online users. [Complete List]
» 4 Member(s) | 5872 Guest(s)
AvatarAvatarAvatarAvatar
