Philco 16 escutcheon screws
Where could I get some? Or should I just get any two of appropriate size and paint them brown?
Philco 16 escutcheon screws - by morzh - 12-17-2016, 12:00 AM
RE: Philco 16 escutcheon screws - by OldRestorer - 12-17-2016, 12:03 AM
RE: Philco 16 escutcheon screws - by morzh - 12-17-2016, 12:08 AM
RE: Philco 16 escutcheon screws - by morzh - 12-17-2016, 02:37 PM
RE: Philco 16 escutcheon screws - by OldRestorer - 12-17-2016, 04:36 PM
RE: Philco 16 escutcheon screws - by morzh - 12-17-2016, 07:50 PM
RE: Philco 16 escutcheon screws - by OldRestorer - 12-17-2016, 09:27 PM
RE: Philco 16 escutcheon screws - by morzh - 12-17-2016, 09:33 PM
There are currently 8735 online users. [Complete List]
» 3 Member(s) | 8732 Guest(s)
