Philco 16 escutcheon screws
Small screws, the thread would be same as any cath Philco escutcheon, the head is almost spherical, for flat screwdriver. Dark chocolate brown.
Philco 16 escutcheon screws - by morzh - 12-17-2016, 12:00 AM
RE: Philco 16 escutcheon screws - by OldRestorer - 12-17-2016, 12:03 AM
RE: Philco 16 escutcheon screws - by morzh - 12-17-2016, 12:08 AM
RE: Philco 16 escutcheon screws - by morzh - 12-17-2016, 02:37 PM
RE: Philco 16 escutcheon screws - by OldRestorer - 12-17-2016, 04:36 PM
RE: Philco 16 escutcheon screws - by morzh - 12-17-2016, 07:50 PM
RE: Philco 16 escutcheon screws - by OldRestorer - 12-17-2016, 09:27 PM
RE: Philco 16 escutcheon screws - by morzh - 12-17-2016, 09:33 PM
Philco 91 Tuning Condenser
There are currently 5969 online users. [Complete List]
» 2 Member(s) | 5967 Guest(s)
