Doerle 2 tube build.
Hi,
I'm getting ready to build the radio and have a question. On the schematic where does the other side of R2 connect? Does it go to ground?
Andy
Doerle 2 tube build. - by Andy - 12-17-2016, 06:00 PM
RE: Doerle 2 tube build. - by Radioroslyn - 12-17-2016, 06:10 PM
RE: Doerle 2 tube build. - by Andy - 12-17-2016, 06:15 PM
RE: Doerle 2 tube build. - by Radioroslyn - 12-17-2016, 06:29 PM
RE: Doerle 2 tube build. - by klondike98 - 12-17-2016, 06:26 PM
RE: Doerle 2 tube build. - by Andy - 12-17-2016, 06:32 PM
RE: Doerle 2 tube build. - by Andy - 12-17-2016, 06:34 PM
RCA T62 is playing.....
Philco 91 Restore Code ??
Philco 40-120C Restoration
Philco 89 indicator light.
