Voltage reducer?
The single most effective way for large radios is the bucking transformer. If you want it inside the radio.
Basically it is simply a transformer that converts 120V to say 12V, and then the 120V AC is put through the secondary in counterphase so the 12V gets subtracted from 120V. Then it gets to the actual radio's transformer's primary.
The secondary has to be for the same current as the radio's primary.
http://dynacotubeaudio.forumotion.com/t3...ransformer
Voltage reducer? - by samsdad - 12-19-2016, 01:56 PM
RE: Voltage reducer? - by morzh - 12-19-2016, 02:16 PM
RE: Voltage reducer? - by samsdad - 12-19-2016, 02:39 PM
RE: Voltage reducer? - by Radioroslyn - 12-19-2016, 06:00 PM
RE: Voltage reducer? - by David - 12-19-2016, 05:47 PM
RE: Voltage reducer? - by morzh - 12-19-2016, 09:12 PM
RE: Voltage reducer? - by Mondial - 12-19-2016, 11:44 PM
RE: Voltage reducer? - by morzh - 12-20-2016, 09:22 AM
RE: Voltage reducer? - by samsdad - 12-20-2016, 11:30 PM
RE: Voltage reducer? - by Arran - 12-24-2016, 04:08 AM
RE: Voltage reducer? - by AI2V - 02-06-2017, 01:03 PM
RE: Voltage reducer? - by morzh - 02-06-2017, 03:37 PM
RE: Voltage reducer? - by Steve Davis - 02-06-2017, 06:35 PM
New member
Good picture, When was it taken? You don't look in it like a guy who has a teenage son :)morzh — 06:13 PM
New member
Philco 630csx power cord
New member
There are currently 4338 online users. [Complete List]
» 1 Member(s) | 4337 Guest(s)
