Reneamed: Winter Electronic restorations
I finished my RCA but I don't know about the grill cloth...
What do you guys think?
I did a full recap and only had to replace one resistor that was 500K and measured 1.3M! it was 5% tolerance too,, Eek... This was quite an easy restore since the radio was playing so well before.
 I also restored my Zenith 6-S-511 which was a bit harder... We all know about Zeniths cramped chassisand the "touch a wire and the rubber cracks off" so I went ahead and replaced what needed it. The presets were extremely dirty and when you put it on broadcast it would just fizzle.. A gallon of cleaner and filing the points and she is all better....
 The one thing I did not do was bypass the 6X5G...
Do you guys think I should do this for safety reasons?
I have done it before and I have it saved that you disconnect the wire to pins 3/5 and the wire to pin 8. Then add a diode and a 150ohm resistor at 5w in series...
Am I off?
Thanks
RE: I need to visit the electronics section more... - by OldRestorer - 12-20-2016, 01:29 PM
RCA T62 is playing.....
Philco 91 Restore Code ??
Philco 40-120C Restoration
Philco 89 indicator light.
