Model 81 Cabinet Restoration
I think you did a very good job repairing the damage to the corners of the base. And the finish looks really good. Maybe you should work on the veneer lifting around the controls. But one thing stands out; where did you get that grill cloth?
Model 81 Cabinet Restoration - by Bill Bacco - 12-16-2015, 10:43 AM
RE: Model 81 Cabinet Restoration - by klondike98 - 12-16-2015, 01:28 PM
RE: Model 81 Cabinet Restoration - by Bill Bacco - 12-16-2015, 02:45 PM
RE: Model 81 Cabinet Restoration - by klondike98 - 12-16-2015, 03:07 PM
RE: Model 81 Cabinet Restoration - by Bill Bacco - 12-16-2015, 09:19 PM
RE: Model 81 Cabinet Restoration - by klondike98 - 12-16-2015, 09:55 PM
RE: Model 81 Cabinet Restoration - by Bill Bacco - 12-22-2015, 09:19 AM
RE: Model 81 Cabinet Restoration - by klondike98 - 12-22-2015, 10:00 AM
RE: Model 81 Cabinet Restoration - by Steve Davis - 12-22-2015, 11:04 AM
RE: Model 81 Cabinet Restoration - by OldRestorer - 12-22-2015, 02:33 PM
RE: Model 81 Cabinet Restoration - by TimC - 12-23-2015, 06:42 PM
RE: Model 81 Cabinet Restoration - by Bill Bacco - 03-26-2016, 02:03 PM
RE: Model 81 Cabinet Restoration - by Radioroslyn - 03-26-2016, 09:34 PM
RE: Model 81 Cabinet Restoration - by Bill Bacco - 03-26-2016, 11:03 PM
RE: Model 81 Cabinet Restoration - by Bill Bacco - 04-03-2016, 09:36 AM
RE: Model 81 Cabinet Restoration - by Radioroslyn - 04-03-2016, 11:04 AM
RE: Model 81 Cabinet Restoration - by klondike98 - 04-03-2016, 11:28 AM
RE: Model 81 Cabinet Restoration - by Bill Bacco - 04-03-2016, 01:52 PM
RE: Model 81 Cabinet Restoration - by Bill Bacco - 07-17-2016, 01:06 PM
RE: Model 81 Cabinet Restoration - by klondike98 - 07-17-2016, 02:15 PM
RE: Model 81 Cabinet Restoration - by Bill Bacco - 12-20-2016, 09:47 PM
RE: Model 81 Cabinet Restoration - by Bill Bacco - 12-20-2016, 09:51 PM
RE: Model 81 Cabinet Restoration - by KCMike - 12-20-2016, 10:17 PM
RE: Model 81 Cabinet Restoration - by Dennis Craft - 12-21-2016, 10:13 AM
RE: Model 81 Cabinet Restoration - by klondike98 - 12-21-2016, 10:28 AM
RE: Model 81 Cabinet Restoration - by Bill Bacco - 12-21-2016, 09:06 PM
RE: Model 81 Cabinet Restoration - by klondike98 - 12-21-2016, 10:59 PM
RE: Model 81 Cabinet Restoration - by Ron Ramirez - 12-22-2016, 07:29 AM
RE: Model 81 Cabinet Restoration - by Bill Bacco - 12-22-2016, 09:51 AM
RE: Model 81 Cabinet Restoration - by klondike98 - 12-22-2016, 10:42 AM
RE: Model 81 Cabinet Restoration - by Radioroslyn - 12-22-2016, 01:05 PM
RE: Model 81 Cabinet Restoration - by Bill Bacco - 12-22-2016, 10:20 PM
RE: Model 81 Cabinet Restoration - by Radioroslyn - 12-22-2016, 11:03 PM
RE: Model 81 Cabinet Restoration - by Bill Bacco - 12-29-2016, 05:46 PM
RE: Model 81 Cabinet Restoration - by Bill Bacco - 12-31-2016, 01:52 PM
RE: Model 81 Cabinet Restoration - by Ron Ramirez - 12-31-2016, 01:58 PM
RE: Model 81 Cabinet Restoration - by klondike98 - 12-31-2016, 03:23 PM
RE: Model 81 Cabinet Restoration - by Radioroslyn - 12-31-2016, 11:43 PM
RE: Model 81 Cabinet Restoration - by Bill Bacco - 01-01-2017, 10:34 AM
RE: Model 81 Cabinet Restoration - by Bill Bacco - 03-11-2017, 10:28 AM
RE: Model 81 Cabinet Restoration - by klondike98 - 03-11-2017, 11:50 AM
Users browsing this thread: 13 Guest(s)
Philco 91 Tuning Condenser
There are currently 8885 online users. [Complete List]
» 3 Member(s) | 8882 Guest(s)
