Model 81 Cabinet Restoration
The 81 had a police band so I think that the dial might be correct. I don't know if its a reproduction or an original though...
The grill cloth is not original to the set. The original was a small herringbone pattern that can be seen (sort of) in this gallery photo: http://www.philcoradio.com/gallery/1933a.htm#h
Its now reproduced and sold by Kenneth Richmond as I mentioned earlier.
Model 81 Cabinet Restoration - by Bill Bacco - 12-16-2015, 10:43 AM
RE: Model 81 Cabinet Restoration - by klondike98 - 12-16-2015, 01:28 PM
RE: Model 81 Cabinet Restoration - by Bill Bacco - 12-16-2015, 02:45 PM
RE: Model 81 Cabinet Restoration - by klondike98 - 12-16-2015, 03:07 PM
RE: Model 81 Cabinet Restoration - by Bill Bacco - 12-16-2015, 09:19 PM
RE: Model 81 Cabinet Restoration - by klondike98 - 12-16-2015, 09:55 PM
RE: Model 81 Cabinet Restoration - by Bill Bacco - 12-22-2015, 09:19 AM
RE: Model 81 Cabinet Restoration - by klondike98 - 12-22-2015, 10:00 AM
RE: Model 81 Cabinet Restoration - by Steve Davis - 12-22-2015, 11:04 AM
RE: Model 81 Cabinet Restoration - by OldRestorer - 12-22-2015, 02:33 PM
RE: Model 81 Cabinet Restoration - by TimC - 12-23-2015, 06:42 PM
RE: Model 81 Cabinet Restoration - by Bill Bacco - 03-26-2016, 02:03 PM
RE: Model 81 Cabinet Restoration - by Radioroslyn - 03-26-2016, 09:34 PM
RE: Model 81 Cabinet Restoration - by Bill Bacco - 03-26-2016, 11:03 PM
RE: Model 81 Cabinet Restoration - by Bill Bacco - 04-03-2016, 09:36 AM
RE: Model 81 Cabinet Restoration - by Radioroslyn - 04-03-2016, 11:04 AM
RE: Model 81 Cabinet Restoration - by klondike98 - 04-03-2016, 11:28 AM
RE: Model 81 Cabinet Restoration - by Bill Bacco - 04-03-2016, 01:52 PM
RE: Model 81 Cabinet Restoration - by Bill Bacco - 07-17-2016, 01:06 PM
RE: Model 81 Cabinet Restoration - by klondike98 - 07-17-2016, 02:15 PM
RE: Model 81 Cabinet Restoration - by Bill Bacco - 12-20-2016, 09:47 PM
RE: Model 81 Cabinet Restoration - by Bill Bacco - 12-20-2016, 09:51 PM
RE: Model 81 Cabinet Restoration - by KCMike - 12-20-2016, 10:17 PM
RE: Model 81 Cabinet Restoration - by klondike98 - 12-21-2016, 10:28 AM
RE: Model 81 Cabinet Restoration - by Bill Bacco - 12-21-2016, 09:06 PM
RE: Model 81 Cabinet Restoration - by klondike98 - 12-21-2016, 10:59 PM
RE: Model 81 Cabinet Restoration - by Ron Ramirez - 12-22-2016, 07:29 AM
RE: Model 81 Cabinet Restoration - by Bill Bacco - 12-22-2016, 09:51 AM
RE: Model 81 Cabinet Restoration - by klondike98 - 12-22-2016, 10:42 AM
RE: Model 81 Cabinet Restoration - by Radioroslyn - 12-22-2016, 01:05 PM
RE: Model 81 Cabinet Restoration - by Bill Bacco - 12-22-2016, 10:20 PM
RE: Model 81 Cabinet Restoration - by Radioroslyn - 12-22-2016, 11:03 PM
RE: Model 81 Cabinet Restoration - by Bill Bacco - 12-29-2016, 05:46 PM
RE: Model 81 Cabinet Restoration - by Bill Bacco - 12-31-2016, 01:52 PM
RE: Model 81 Cabinet Restoration - by Ron Ramirez - 12-31-2016, 01:58 PM
RE: Model 81 Cabinet Restoration - by klondike98 - 12-31-2016, 03:23 PM
RE: Model 81 Cabinet Restoration - by Radioroslyn - 12-31-2016, 11:43 PM
RE: Model 81 Cabinet Restoration - by Bill Bacco - 01-01-2017, 10:34 AM
RE: Model 81 Cabinet Restoration - by Bill Bacco - 03-11-2017, 10:28 AM
RE: Model 81 Cabinet Restoration - by klondike98 - 03-11-2017, 11:50 AM
Philco 91 Tuning Condenser
There are currently 8828 online users. [Complete List]
» 3 Member(s) | 8825 Guest(s)
