Model 81 Cabinet Restoration
#31
Thanks for all of the feedback, I appreciate it. I'll paint the screw heads.
I reached out to Ken to see if he would sell a smaller piece at a reduced price, but based on what he offered it probably doesn't make sense to buy the smaller piece. $16.50 for 12x12 vs. $20 for 18x24. I am struggling a bit as to whether I want to put another $20 into this radio, since I only need a 1/4 of that grill cloth and may not need the rest ever again.
Any opinions as to whether it makes sense to put another $20 into this radio? I understand that from a purist perspective it will keep it original looking. However, if I ever decide to sell it will it make that much of a difference as to what it is worth?
Thanks, Bill
Model 81 Cabinet Restoration - by Bill Bacco - 12-16-2015, 10:43 AM
RE: Model 81 Cabinet Restoration - by klondike98 - 12-16-2015, 01:28 PM
RE: Model 81 Cabinet Restoration - by Bill Bacco - 12-16-2015, 02:45 PM
RE: Model 81 Cabinet Restoration - by klondike98 - 12-16-2015, 03:07 PM
RE: Model 81 Cabinet Restoration - by Bill Bacco - 12-16-2015, 09:19 PM
RE: Model 81 Cabinet Restoration - by klondike98 - 12-16-2015, 09:55 PM
RE: Model 81 Cabinet Restoration - by Bill Bacco - 12-22-2015, 09:19 AM
RE: Model 81 Cabinet Restoration - by klondike98 - 12-22-2015, 10:00 AM
RE: Model 81 Cabinet Restoration - by Steve Davis - 12-22-2015, 11:04 AM
RE: Model 81 Cabinet Restoration - by OldRestorer - 12-22-2015, 02:33 PM
RE: Model 81 Cabinet Restoration - by TimC - 12-23-2015, 06:42 PM
RE: Model 81 Cabinet Restoration - by Bill Bacco - 03-26-2016, 02:03 PM
RE: Model 81 Cabinet Restoration - by Radioroslyn - 03-26-2016, 09:34 PM
RE: Model 81 Cabinet Restoration - by Bill Bacco - 03-26-2016, 11:03 PM
RE: Model 81 Cabinet Restoration - by Bill Bacco - 04-03-2016, 09:36 AM
RE: Model 81 Cabinet Restoration - by Radioroslyn - 04-03-2016, 11:04 AM
RE: Model 81 Cabinet Restoration - by klondike98 - 04-03-2016, 11:28 AM
RE: Model 81 Cabinet Restoration - by Bill Bacco - 04-03-2016, 01:52 PM
RE: Model 81 Cabinet Restoration - by Bill Bacco - 07-17-2016, 01:06 PM
RE: Model 81 Cabinet Restoration - by klondike98 - 07-17-2016, 02:15 PM
RE: Model 81 Cabinet Restoration - by Bill Bacco - 12-20-2016, 09:47 PM
RE: Model 81 Cabinet Restoration - by Bill Bacco - 12-20-2016, 09:51 PM
RE: Model 81 Cabinet Restoration - by KCMike - 12-20-2016, 10:17 PM
RE: Model 81 Cabinet Restoration - by klondike98 - 12-21-2016, 10:28 AM
RE: Model 81 Cabinet Restoration - by Bill Bacco - 12-21-2016, 09:06 PM
RE: Model 81 Cabinet Restoration - by klondike98 - 12-21-2016, 10:59 PM
RE: Model 81 Cabinet Restoration - by Ron Ramirez - 12-22-2016, 07:29 AM
RE: Model 81 Cabinet Restoration - by Bill Bacco - 12-22-2016, 09:51 AM
RE: Model 81 Cabinet Restoration - by klondike98 - 12-22-2016, 10:42 AM
RE: Model 81 Cabinet Restoration - by Radioroslyn - 12-22-2016, 01:05 PM
RE: Model 81 Cabinet Restoration - by Bill Bacco - 12-22-2016, 10:20 PM
RE: Model 81 Cabinet Restoration - by Radioroslyn - 12-22-2016, 11:03 PM
RE: Model 81 Cabinet Restoration - by Bill Bacco - 12-29-2016, 05:46 PM
RE: Model 81 Cabinet Restoration - by Bill Bacco - 12-31-2016, 01:52 PM
RE: Model 81 Cabinet Restoration - by Ron Ramirez - 12-31-2016, 01:58 PM
RE: Model 81 Cabinet Restoration - by klondike98 - 12-31-2016, 03:23 PM
RE: Model 81 Cabinet Restoration - by Radioroslyn - 12-31-2016, 11:43 PM
RE: Model 81 Cabinet Restoration - by Bill Bacco - 01-01-2017, 10:34 AM
RE: Model 81 Cabinet Restoration - by Bill Bacco - 03-11-2017, 10:28 AM
RE: Model 81 Cabinet Restoration - by klondike98 - 03-11-2017, 11:50 AM
Philco 91 Tuning Condenser
There are currently 8935 online users. [Complete List]
» 1 Member(s) | 8934 Guest(s)
