37-630 Intermittent issue - solved
In the model 660 it is a 2K resistor.
In the 37-116 it is 1K.
The less the resistance for the given meter the narrower the segment will become.
RE: 37-630 Intermittent issue - solved - by morzh - 12-22-2016, 04:36 PM
RE: 37-630 Intermittent issue - solved - by morzh - 12-22-2016, 05:37 PM
RE: 37-630 Intermittent issue - solved - by morzh - 12-22-2016, 11:22 PM
RE: 37-630 Intermittent issue - solved - by morzh - 12-23-2016, 11:56 AM
46-1201 Trip Switch Spring
So, Q1. Does anyone know where to get the spider. Q2. If there is no such place, what material is best? I doubt tin is...morzh — 09:43 PM
Arran The oxidation seems to go deep, a few layers. The break starts right there, but then it will occur on every la...morzh — 07:35 PM
There are currently 3454 online users. [Complete List]
» 1 Member(s) | 3453 Guest(s)
