Philco 46-350... capacitor with wire wrapped around it.
(12-23-2016, 10:56 PM)TerryMSU Wrote:  What is up with C21 on the Philco 36-350?  It has a knot of wire around it.  The note says to duplicate it if you replace the capacitor.  The problem is that I will be using a different physical sized part.  I am tempted to either just slide it loosely around the new part or maybe just not replace that capacitor altogether.  It is a 0.1 uF paper cap.  A yellow Mylar will be a smaller diameter.
TerryMSU
You could always cut the leads off the original and leave the "knot of wire" in place then solder the new cap at the contact points. You will be leaving the wire as is and have a new cap too.
46-1201 Trip Switch Spring
So, Q1. Does anyone know where to get the spider. Q2. If there is no such place, what material is best? I doubt tin is...morzh — 09:43 PM
Arran The oxidation seems to go deep, a few layers. The break starts right there, but then it will occur on every la...morzh — 07:35 PM
There are currently 8204 online users. [Complete List]
» 1 Member(s) | 8203 Guest(s)
