6X5 bypass question
I would just put a fuse in the primary lead of the power transformer and stop worrying about it. This applies either to the 6X5 tube or a replacement silicon rectifier.
Rate the fuse marginally higher than the maximum current draw of the radio under normal operation. If the rectifier should short, it will blow the fuse within a few seconds, protecting the transformer from any sustained overload.
6X5 bypass question - by OldRestorer - 12-21-2016, 02:05 PM
RE: 6X5 bypass question - by morzh - 12-21-2016, 02:14 PM
RE: 6X5 bypass question - by OldRestorer - 12-21-2016, 10:51 PM
RE: 6X5 bypass question - by morzh - 12-21-2016, 10:57 PM
RE: 6X5 bypass question - by TV MAN - 12-22-2016, 11:10 AM
RE: 6X5 bypass question - by morzh - 12-22-2016, 11:42 AM
RE: 6X5 bypass question - by OldRestorer - 12-22-2016, 12:03 PM
RE: 6X5 bypass question - by morzh - 12-22-2016, 12:58 PM
RE: 6X5 bypass question - by Mondial - 12-22-2016, 01:21 PM
RE: 6X5 bypass question - by OldRestorer - 12-22-2016, 01:45 PM
RE: 6X5 bypass question - by morzh - 12-22-2016, 02:24 PM
RE: 6X5 bypass question - by Mondial - 12-22-2016, 04:21 PM
RE: 6X5 bypass question - by morzh - 12-22-2016, 04:40 PM
RE: 6X5 bypass question - by TV MAN - 12-22-2016, 02:50 PM
RE: 6X5 bypass question - by morzh - 12-22-2016, 03:46 PM
RE: 6X5 bypass question - by TV MAN - 12-23-2016, 11:05 AM
RE: 6X5 bypass question - by Arran - 12-24-2016, 02:40 AM
RE: 6X5 bypass question - by Mondial - 12-24-2016, 12:05 AM
RE: 6X5 bypass question - by Arran - 12-24-2016, 02:26 AM
RE: 6X5 bypass question - by morzh - 12-24-2016, 11:53 AM
RE: 6X5 bypass question - by Arran - 12-25-2016, 12:49 AM
RE: 6X5 bypass question - by morzh - 12-25-2016, 01:15 PM
Philco 89 indicator light.
46-1201 Trip Switch Spring
There are currently 7443 online users. [Complete List]
» 1 Member(s) | 7442 Guest(s)
