Model 801 conversion to AC question
 I believe that they converted these pretty much as Terry suggested, even leaving the original rectifier and filter cap can. I've never owned one, though I would like to at some point, but from the photos I have seen they didn't have enough room on the chassis of the MoPar 801 to bolt an AC power transformer so they screwed a vertically mounted transformer inside the cabinet and extended the leads to connect to the car radio chassis. I believe that in the consoles that used a Ford car radio chassis they did have enough space to mount an AC power transformer on the chassis, or at least on the outside of it.
Model 801 conversion to AC question - by RAH1915 - 12-23-2016, 06:45 PM
RE: Model 801 conversion to AC question - by Arran - 12-24-2016, 01:43 AM
Eico 232 VTVM Schematic
There are currently 5019 online users. [Complete List]
» 2 Member(s) | 5017 Guest(s)
