My 1942 Philco 42-380X Radio project
You could have restored the original electronics of that radio for less then the cost of that flat screen and the other computer parts, and the set would have been worth more monetarily and historically. If you wanted a memento to your grandparents why deface a perfectly good radio by fitting a PC inside it's cabinet that will be worthless junk in under five years? I can only hope that the cabinet hasn't been hacked up or so full of holes that if you can put it back the way it was someday, assuming of course that you didn't toss out the original parts already.
My 1942 Philco 42-380X Radio project - by Guest - 11-10-2009, 02:10 PM
Re: My 1942 Philco 42-380X Radio project - by Arran - 11-11-2009, 01:25 AM
Re: My 1942 Philco 42-380X Radio project - by Guest - 11-11-2009, 10:01 AM
