Philco 46-350
Seems like you have a short across the B+ supply. Is the polarity correct on all the electrolytic caps?
With the set unplugged, measure with an ohmmeter from pin 6 of the 117Z3 to common negative of the filter caps.
You should see a high and rising resistance value.
Disconnect the wire from R100A to pin 6 of the 117Z3 and power up slowly. See if the input current is still high and if you now have around 90 VDC at pin 6 with normal AC input voltage.
Philco 46-350 - by vecher - 12-01-2016, 10:15 PM
RE: Philco 46-350 - by Mondial - 12-01-2016, 10:42 PM
RE: Philco 46-350 - by vecher - 12-01-2016, 10:47 PM
RE: Philco 46-350 - by vecher - 12-24-2016, 12:41 AM
RE: Philco 46-350 - by Arran - 12-24-2016, 04:47 AM
RE: Philco 46-350 - by vecher - 12-25-2016, 11:55 PM
RE: Philco 46-350 - by Mondial - 12-26-2016, 12:41 AM
RE: Philco 46-350 - by vecher - 12-26-2016, 04:05 PM
RE: Philco 46-350 - by Mondial - 12-26-2016, 04:22 PM
RE: Philco 46-350 - by vecher - 12-26-2016, 05:20 PM
RE: Philco 46-350 - by Radioroslyn - 12-26-2016, 07:21 PM
RE: Philco 46-350 - by Kenneth F. Besso Jr. - 12-26-2016, 08:07 PM
RE: Philco 46-350 - by vecher - 12-26-2016, 08:15 PM
RE: Philco 46-350 - by vecher - 12-27-2016, 06:55 PM
RE: Philco 46-350 - by vecher - 12-27-2016, 07:48 PM
RE: Philco 46-350 - by vecher - 12-27-2016, 10:18 PM
46-1201 Trip Switch Spring
So, Q1. Does anyone know where to get the spider. Q2. If there is no such place, what material is best? I doubt tin is...morzh — 09:43 PM
Arran The oxidation seems to go deep, a few layers. The break starts right there, but then it will occur on every la...morzh — 07:35 PM
