Shortwave Converter
Has anyone had any experience with an early thirties shortwave converter? I have a Deforest Crosley model 201B that has two tubes, a 27 and a 24A. It is almost identical to the Stewart Warner 301. What I am wondering is what is the output signal supposed to be or how would one determine it. It says nothing on the schematic.
Gregb
Shortwave Converter - by gregb - 12-27-2016, 01:49 AM
RE: Shortwave Converter - by Radioroslyn - 12-27-2016, 09:08 AM
RE: Shortwave Converter - by Phlogiston - 12-27-2016, 01:38 PM
RE: Shortwave Converter - by gregb - 12-27-2016, 02:33 PM
RCA T62 is playing.....
Philco 91 Restore Code ??
Philco 40-120C Restoration
Philco 89 indicator light.
