filament transformer
(12-26-2016, 10:42 PM)morzh Wrote:  If you restored it back to 2.5V why do you need the transformer anymore?
Good question, i want to use it to power a 1.5 v iJ5 tube which is the opt tube in a Zenith 6 J 230, a 6volt or 115 v ac set. all other tubes are 6 volt but the 1J5 has it's filament supplied via two special dial lights (blown) and resistors.
To avoid this i want to use the trans with a rewind and tappings to get 1.5 v.
filament transformer - by sandbar40 - 12-26-2016, 10:26 PM
RE: filament transformer - by morzh - 12-26-2016, 10:42 PM
RE: filament transformer - by sandbar40 - 12-27-2016, 10:31 PM
RCA T62 is playing.....
Philco 91 Restore Code ??
Philco 40-120C Restoration
Philco 89 indicator light.
There are currently 8617 online users. [Complete List]
» 3 Member(s) | 8614 Guest(s)
