Model 51-1330 Recap
Hi and welcome to the Phorum,
>Thoughts on why the C5 was removed ?
Not really but set won't work well at all without it as it's ground return for the osc coil. With just the resistor there would think that would couple ac up to the b- circuit. C5 also provide a ground for the two IF cans which could pickup hum without it connected.
Neutral side of the line should go to the off/on switch on the set.
Model 51-1330 Recap - by Ariac - 12-28-2016, 05:08 PM
RE: Model 51-1330 Recap - by David - 12-28-2016, 08:17 PM
RE: Model 51-1330 Recap - by Radioroslyn - 12-28-2016, 09:41 PM
RE: Model 51-1330 Recap - by Ariac - 12-30-2016, 09:43 AM
RE: Model 51-1330 Recap - by Ariac - 12-31-2016, 01:39 PM
RE: Model 51-1330 Recap - by Squire - 01-05-2017, 11:43 PM
RE: Model 51-1330 Recap - by Ariac - 01-06-2017, 08:25 PM
46-1201 Trip Switch Spring
So, Q1. Does anyone know where to get the spider. Q2. If there is no such place, what material is best? I doubt tin is...morzh — 09:43 PM
Arran The oxidation seems to go deep, a few layers. The break starts right there, but then it will occur on every la...morzh — 07:35 PM
