Kirk's Sterling deluxe
Well, here's another one.
No sch.
No info.
The tube lineup is 4 tubes, 12BE6, 12AT6, 50B5 and 35W4.
Very similar to some other cheap miniature tube-based ones.
The oscillator arrangement is the same as in the Garod I just finished.
No frame/mag antenna
 Now the radio receives the strong local station and judging by the tuning cap position it is in the vicinity of where it should be.
The problem is two-fold: 1) no other stations meaning very low sensitivity, 2) strong hum. Changes with volume, no change due to the tuning.
Would really like to have the sch.
Kirk's Sterling deluxe - by morzh - 12-31-2016, 08:51 PM
RE: Kirk's Sterling deluxe - by morzh - 12-31-2016, 10:09 PM
RE: Kirk's Sterling deluxe - by Radioroslyn - 12-31-2016, 11:52 PM
RE: Kirk's Sterling deluxe - by OldRestorer - 01-01-2017, 01:40 PM
RE: Kirk's Sterling deluxe - by morzh - 01-01-2017, 02:25 PM
RE: Kirk's Sterling deluxe - by Carl Travis - 01-01-2017, 04:42 PM
RE: Kirk's Sterling deluxe - by morzh - 01-01-2017, 05:26 PM
RE: Kirk's Sterling deluxe - by morzh - 01-02-2017, 06:05 PM
RE: Kirk's Sterling deluxe - by morzh - 01-15-2017, 10:35 PM
RE: Kirk's Sterling deluxe - by Arran - 01-16-2017, 06:01 AM
RE: Kirk's Sterling deluxe - by morzh - 01-16-2017, 10:12 AM
RE: Kirk's Sterling deluxe - by gregb - 01-16-2017, 11:51 AM
RE: Kirk's Sterling deluxe - by morzh - 01-16-2017, 12:58 PM
RE: Kirk's Sterling deluxe - by gregb - 01-16-2017, 05:50 PM
RE: Kirk's Sterling deluxe - by gregb - 01-16-2017, 09:24 PM
RE: Kirk's Sterling deluxe - by morzh - 01-16-2017, 10:39 PM
RE: Kirk's Sterling deluxe - by morzh - 01-16-2017, 10:55 PM
RE: Kirk's Sterling deluxe - by gregb - 01-16-2017, 11:22 PM
RE: Kirk's Sterling deluxe - by gregb - 01-17-2017, 12:15 AM
RE: Kirk's Sterling deluxe - by morzh - 01-17-2017, 09:07 AM
RE: Kirk's Sterling deluxe - by Arran - 01-19-2017, 07:04 AM
RE: Kirk's Sterling deluxe - by morzh - 01-19-2017, 08:59 AM
RE: Kirk's Sterling deluxe - by Arran - 01-21-2017, 06:12 AM
RE: Kirk's Sterling deluxe - by morzh - 01-21-2017, 12:36 PM
RE: Kirk's Sterling deluxe - by morzh - 02-01-2017, 11:26 PM
RE: Kirk's Sterling deluxe - by OldRestorer - 02-02-2017, 11:46 AM
RE: Kirk's Sterling deluxe - by morzh - 02-02-2017, 04:05 PM
RCA T62 is playing.....
Philco 91 Restore Code ??
Philco 40-120C Restoration
Philco 89 indicator light.
There are currently 3778 online users. [Complete List]
» 1 Member(s) | 3777 Guest(s)
