Model FM-61 Automatic brand fm converter.
(01-02-2017, 02:39 PM)flatheadjr Wrote:  I think I may have it, I had to turn the screw about 1/8 more and they're all on, I just need to slide my indicator about 3/8 to the left and everything should line up. I probably still need to change the electrolytic capacitors in this for it to be completely reliable. I couldn't find the exact value for this unit, it calls for 400mfd @ 15 volts, best I could get was 470mfd at 25 volts, will that be okay?
Yup you fine.
RE: Model FM-61 Automatic brand fm converter. - by Radioroslyn - 01-02-2017, 04:15 PM
Philco 89 indicator light.
46-1201 Trip Switch Spring
There are currently 6629 online users. [Complete List]
» 2 Member(s) | 6627 Guest(s)
