Philco 116-122 Console
It sounds like either a filter cap is failing, or the insulation between the 5 v filament winding of the power transformer and ground is breaking down. With the 5Z3 removed, there will be no B+ on the filament winding, so the leakage to ground will not show up.
You can disconnect each filter cap one at a time, but it would be better if you temporarily replaced it with another cap. Otherwise you will subject the speaker and other components to a lot of AC ripple voltage.
Since the problem still shows up without the rest of the tubes installed it would be better to test with just the 5Z3 plugged in.
Philco 116-122 Console - by Crist Rigotti - 01-04-2017, 09:31 PM
RE: Philco 116-122 Console - by Radioroslyn - 01-04-2017, 10:21 PM
RE: Philco 116-122 Console - by Mondial - 01-04-2017, 10:30 PM
RE: Philco 116-122 Console - by Crist Rigotti - 01-05-2017, 12:05 AM
RE: Philco 116-122 Console - by Mondial - 01-05-2017, 12:23 AM
RE: Philco 116-122 Console - by Crist Rigotti - 01-05-2017, 03:35 AM
RE: Philco 116-122 Console - by Phlogiston - 01-05-2017, 12:13 PM
RE: Philco 116-122 Console - by Mondial - 01-05-2017, 08:45 AM
RE: Philco 116-122 Console - by Crist Rigotti - 01-05-2017, 11:29 AM
RE: Philco 116-122 Console - by Mondial - 01-05-2017, 01:13 PM
46-1201 Trip Switch Spring
So, Q1. Does anyone know where to get the spider. Q2. If there is no such place, what material is best? I doubt tin is...morzh — 09:43 PM
Arran The oxidation seems to go deep, a few layers. The break starts right there, but then it will occur on every la...morzh — 07:35 PM
There are currently 7532 online users. [Complete List]
» 1 Member(s) | 7531 Guest(s)
