Radiola 60 ??
Here is a couple of pictures of a RCA Radiola 60 ?? I saw this in a antique store up by me .. Looked in great condition.. Does anyone know anything about this.. I didn't get it yet due to not knowing what to offer Any clues on what its worth.. How difficult to work on Problems ETC...
[Image: http://i292.photobucket.com/albums/mm38/...hzjtfm.jpg]
[Image: http://i292.photobucket.com/albums/mm38/...xfzqpw.jpg]
[Image: http://i292.photobucket.com/albums/mm38/...kh2lje.jpg]
Thanks
Skip...
Radiola 60 ?? - by vecher - 01-05-2017, 01:01 AM
RE: Radiola 60 ?? - by Arran - 01-05-2017, 04:54 AM
RE: Radiola 60 ?? - by Fred Taylor - 01-05-2017, 08:54 AM
RE: Radiola 60 ?? - by Mondial - 01-05-2017, 09:07 AM
RE: Radiola 60 ?? - by Jayce - 01-05-2017, 12:48 PM
RE: Radiola 60 ?? - by klondike98 - 01-05-2017, 01:32 PM
RE: Radiola 60 ?? - by vecher - 01-05-2017, 01:58 PM
RE: Radiola 60 ?? - by vecher - 01-05-2017, 03:50 PM
RE: Radiola 60 ?? - by Arran - 01-09-2017, 05:11 AM
RE: Radiola 60 ?? - by Jayce - 01-06-2017, 12:13 AM
RE: Radiola 60 ?? - by Fred Taylor - 01-06-2017, 08:44 AM
RE: Radiola 60 ?? - by Jayce - 01-09-2017, 07:46 PM
RE: Radiola 60 ?? - by Arran - 01-10-2017, 04:49 AM
RE: Radiola 60 ?? - by Jayce - 01-15-2017, 01:18 PM
RE: Radiola 60 ?? - by Phlogiston - 01-15-2017, 03:13 PM
RCA T62 is playing.....
Philco 91 Restore Code ??
Philco 40-120C Restoration
Philco 89 indicator light.
