How to make a new dial cover tutorial
Not trying to be critical, but is anybody else having trouble following this tutorial? I really would like to try this, but I get lost at step 6 where it says: "Then attach the cutout to the center". What is the "cutout", and to the center of what? In step 5, he refers to the cutout as the piece with the hole in it (the masonite-looking material in the picture). Is this the "cutout"? Doesn't look like it in the picture associated with step 6. Why would there be a need to attach it to the "center" of the other half-inch piece of material if the two half-inch pieces are roughly the same size? Does he mean attach the "insert", which is the term he uses for the quarter-inch material (the rounded-corner rectangle) in step 5?
It gets even worse for me in step 7, "bottom of the template", "base of the template", "top of the template", "bottom half"? Maybe too many terms for the same piece, or maybe I'm reading too much into it. The tutorial looks like it has a lot of potential if I could just get through steps 6 and 7. Anybody care to clarify?
RE: New dial cover chronicles - by OldRestorer - 03-19-2014, 08:05 PM
RE: New dial cover chronicles - by OldRestorer - 03-19-2014, 08:07 PM
RE: New dial cover chronicles - by OldRestorer - 03-19-2014, 08:26 PM
RE: New dial cover chronicles - by hsusmann - 03-19-2014, 08:47 PM
RE: New dial cover chronicles - by morzh - 03-19-2014, 08:50 PM
RE: New dial cover chronicles - by skyscraper - 03-19-2014, 09:19 PM
RE: New dial cover chronicles - by OldRestorer - 03-19-2014, 09:52 PM
RE: New dial cover chronicles - by Warren - 03-20-2014, 12:07 AM
RE: New dial cover chronicles - by tab10672 - 03-20-2014, 12:54 AM
RE: New dial cover chronicles - by Warren - 03-20-2014, 02:13 AM
RE: How to make a new dial cover tutorial - by abes.cherif - 02-09-2015, 09:44 PM
RE: How to make a new dial cover tutorial - by mark123 - 01-06-2017, 03:02 PM
There are currently 4392 online users. [Complete List]
» 2 Member(s) | 4390 Guest(s)
