Philco 37-650 mystery wires
Schematic reading/wiring assistance needed!
Im working on a Philco 37-650
http://www.nostalgiaair.org/Resources/219/M0013219.htm
I have a few disconnected/cut wires that I cant seem to figure out where they are supposed to connect.
The first one is this green/yellow wire coming off of pin 4 of the 6K7G tube. The other wire routes around to a bakelite block cap on the other side of the chassis but the other wire is cut/broken and I cant find another stub that looks like the same wire.
[Image: https://scontent-ort2-1.xx.fbcdn.net/v/t...e=5913107E]
The Next one is this mysterious stub on pin 5 of one of the 6F6G output tubes.
[Image: https://scontent-ort2-1.xx.fbcdn.net/v/t...e=5912CC8A]
Can anyone help?
Philco 37-650 mystery wires - by Tgace459 - 01-07-2017, 04:04 PM
RE: Philco 37-650 mystery wires - by Radioroslyn - 01-07-2017, 04:39 PM
RE: Philco 37-650 mystery wires - by Tgace459 - 01-07-2017, 04:47 PM
RE: Philco 37-650 mystery wires - by Radioroslyn - 01-07-2017, 05:12 PM
RE: Philco 37-650 mystery wires - by Tgace459 - 01-07-2017, 05:38 PM
RE: Philco 37-650 mystery wires - by Tgace459 - 01-07-2017, 05:45 PM
RE: Philco 37-650 mystery wires - by Radioroslyn - 01-07-2017, 05:58 PM
RE: Philco 37-650 mystery wires - by Tgace459 - 01-07-2017, 06:15 PM
RE: Philco 37-650 mystery wires - by Tgace459 - 01-07-2017, 06:23 PM
RE: Philco 37-650 mystery wires - by Tgace459 - 01-08-2017, 08:14 PM
RE: Philco 37-650 mystery wires - by Radioroslyn - 01-08-2017, 08:19 PM
RCA T62 is playing.....
Philco 91 Restore Code ??
Philco 40-120C Restoration
Philco 89 indicator light.
There are currently 7342 online users. [Complete List]
» 3 Member(s) | 7339 Guest(s)
