Replacing Rubber Wire
It matters not. Just so long as you are careful withthe bends on solid wire so as not to cause a break, it is a lot easier to handle. Anywhere wiere the wire will physically move durinng normal operation, it should be stranded.
Replacing Rubber Wire - by jjbuzard - 11-27-2009, 04:26 PM
Re: Replacing Rubber Wire - by codefox1 - 11-27-2009, 05:38 PM
Re: Replacing Rubber Wire - by jjbuzard - 11-30-2009, 12:04 PM
Re: Replacing Rubber Wire - by gary rabbitt - 12-22-2009, 03:52 AM
Re: Replacing Rubber Wire - by FStephenMasek - 12-31-2009, 02:05 AM
Re: Replacing Rubber Wire - by Ron Ramirez - 12-31-2009, 10:33 AM
Re: Replacing Rubber Wire - by Sean - 12-31-2009, 04:58 PM
Re: Replacing Rubber Wire - by Guest - 01-16-2010, 12:54 PM
Re: Replacing Rubber Wire - by exray - 01-16-2010, 11:01 PM
Re: Replacing Rubber Wire - by Joe Rossi - 01-17-2010, 12:28 PM
Re: Replacing Rubber Wire - by Ron Ramirez - 01-17-2010, 08:49 PM
Re: Replacing Rubber Wire - by codefox1 - 01-18-2010, 04:07 AM
Re: Replacing Rubber Wire - by MinnesotaHam - 01-18-2010, 07:40 PM
Re: Replacing Rubber Wire - by FStephenMasek - 12-22-2010, 10:28 PM
Re: Replacing Rubber Wire - by TA Forbes - 12-22-2010, 11:10 PM
