Philco 37-650 mystery wires
(01-08-2017, 08:14 PM)Tgace459 Wrote:  Many thanks!
Got her playing for the rest of the recap and restoration....
Good Job!!!
Philco 37-650 mystery wires - by Tgace459 - 01-07-2017, 04:04 PM
RE: Philco 37-650 mystery wires - by Radioroslyn - 01-07-2017, 04:39 PM
RE: Philco 37-650 mystery wires - by Tgace459 - 01-07-2017, 04:47 PM
RE: Philco 37-650 mystery wires - by Radioroslyn - 01-07-2017, 05:12 PM
RE: Philco 37-650 mystery wires - by Tgace459 - 01-07-2017, 05:38 PM
RE: Philco 37-650 mystery wires - by Tgace459 - 01-07-2017, 05:45 PM
RE: Philco 37-650 mystery wires - by Radioroslyn - 01-07-2017, 05:58 PM
RE: Philco 37-650 mystery wires - by Tgace459 - 01-07-2017, 06:15 PM
RE: Philco 37-650 mystery wires - by Tgace459 - 01-07-2017, 06:23 PM
RE: Philco 37-650 mystery wires - by Tgace459 - 01-08-2017, 08:14 PM
RE: Philco 37-650 mystery wires - by Radioroslyn - 01-08-2017, 08:19 PM
RCA T62 is playing.....
Philco 91 Restore Code ??
Philco 40-120C Restoration
Philco 89 indicator light.
There are currently 6875 online users. [Complete List]
» 3 Member(s) | 6872 Guest(s)
