Threads: 566
Here's a question. Riders does not have the sch. The sch has external b!ocks and some pieces but no full sch or chassis drawing.
There is 10H571R but I am not sure it is the same, plus the chassis is different.
Does anyone have the docs for this one or a link I could follow?
RE: Zenith 10-H-571 "Spinet" - by morzh - 01-08-2017, 08:55 PM
Users browsing this thread: 16 Guest(s)
Gary
I in fact did, on a 38-14, I think, where I had a speaker with the dead coil.
Well...it kinda worked. Kinda, be...morzh — 10:38 PM |
Mike, what ever happened to that plan you had to try using a rare earth magnet to magnetize the pole? This looks like a...GarySP — 10:25 PM |
RCA T62 is playing.....
Beautiful set.morzh — 09:07 PM |
Well....here it is.
The green stuff. Unfortunately, probably penetrates deep.
I opened the top layer and saw that:
...morzh — 08:58 PM |
Philco 91 Restore Code ??
:clap: :clap: :clap: :clap:
Really nice workmanship!!! Top of the chassis looks great.
Sorry about the long winded e...MrFixr55 — 08:09 PM |
Philco 40-120C Restoration
Thank you for your reply. I will check voltages on the other tubes, look at resistor 23 and cap 25, etc. If all else fai...bluecap — 07:58 PM |
Nice looking set great save. DavidDavid — 07:48 PM |
Philco 89 indicator light.
Hello Jim, I have done several 89s. The trick is to move the drum in or out on it's shaft. You will need to loosen a set...dconant — 07:36 PM |
MrFixr
Yes, it is my plan to go with 45rpm spider if I go that far.
No, the pole was not left-handed as I unscrewed ...morzh — 07:14 PM |
Change the tube. Check the tube's bias network.
Are any other tubes experience the drop or just this?`
Is resistor 23 OK...morzh — 07:09 PM |
There are currently 6083 online users. [Complete List] » 1 Member(s) | 6082 Guest(s)
