Philco 635
Hi Mike and welcome,
For starters the radio chassis needs to be in tip top shape. This means all new paper and electrolytic caps, all resistor within 20% tolerance and a good set of tubes. Align the rf and IF stages. With a chassis w/poor sensitivity it's a waste of time and is very frustrating to try to get the sm to work properly. A good indication is if you receive a strong signal (from a generator or on air) you should be able to develop about -10v on the avc line.
Use the adjustment screw to set the vane straight. Should be able move the vane by gently blowing on it. If not it's probably centered in it's pivots. Align lamp filament for best shadow.
Generally I find that the sm isn't very sensitive. Doesn't react to weak signals very well. I live in an area where there is a lot of strong signals and a lot of noise.
Philco 635 - by Mike25 - 01-08-2017, 07:42 PM
RE: Philco 635 - by morzh - 01-09-2017, 02:11 PM
RE: Philco 635 - by Radioroslyn - 01-09-2017, 03:25 PM
RE: Philco 635 - by morzh - 01-09-2017, 03:49 PM
RE: Philco 635 - by Mike25 - 01-10-2017, 09:07 PM
RE: Philco 635 - by morzh - 01-11-2017, 12:09 AM
RE: Philco 635 - by Radioroslyn - 01-11-2017, 12:28 AM
RE: Philco 635 - by Mike25 - 01-11-2017, 09:47 AM
RE: Philco 635 - by Radioroslyn - 01-11-2017, 12:49 PM
RE: Philco 635 - by Mike25 - 01-12-2017, 10:29 PM
RE: 650X Shadow Meter question. - by Radioroslyn - 01-09-2017, 01:35 PM
Philco 635 - by klondike98 - 01-09-2017, 01:45 PM
Philco 89 indicator light.
46-1201 Trip Switch Spring
So, Q1. Does anyone know where to get the spider. Q2. If there is no such place, what material is best? I doubt tin is...morzh — 09:43 PM
There are currently 6397 online users. [Complete List]
» 2 Member(s) | 6395 Guest(s)
