Philco 60 tuning shaft slips
Almost done with a model 60. The gear reduction tuning shaft slips at various points. I have cleaned and oiled the bearings to remove any sticking of the capacitor but still get some slip. Any tips on how to clean or fix this?
Thanks
BTW; this work would have been almost impossible without the model 60 evolution information available here. THANKS!
Philco 60 tuning shaft slips - by black85vette - 01-09-2017, 02:42 PM
RE: Philco 60 tuning shaft slips - by klondike98 - 01-09-2017, 02:57 PM
RE: Philco 60 tuning shaft slips - by morzh - 01-09-2017, 03:18 PM
RE: Philco 60 tuning shaft slips - by morzh - 01-09-2017, 03:48 PM
RE: Philco 60 tuning shaft slips - by morzh - 01-10-2017, 12:27 AM
RE: Philco 60 tuning shaft slips - by morzh - 01-10-2017, 09:23 AM
RCA T62 is playing.....
Philco 91 Restore Code ??
Philco 40-120C Restoration
Philco 89 indicator light.
There are currently 4757 online users. [Complete List]
» 2 Member(s) | 4755 Guest(s)
