Philco 60 tuning shaft slips
Another bit that puzzles me. The tuning cap is isolated by the rubber feet, but then has a ground strap soldered to the rear mounting screw by a braided ground strap directly to the chassis. This is a very awkward setup. You have a screw that has solder all over the top making it difficult to remove. Why not just ground the frame of the cap to the chassis directly? I am thinking of putting aluminum or brass spacers under the cap. Is there a valid reason to shock mount the tuning cap??
Philco 60 tuning shaft slips - by black85vette - 01-09-2017, 02:42 PM
RE: Philco 60 tuning shaft slips - by klondike98 - 01-09-2017, 02:57 PM
RE: Philco 60 tuning shaft slips - by morzh - 01-09-2017, 03:18 PM
RE: Philco 60 tuning shaft slips - by morzh - 01-09-2017, 03:48 PM
RE: Philco 60 tuning shaft slips - by morzh - 01-10-2017, 12:27 AM
RE: Philco 60 tuning shaft slips - by black85vette - 01-10-2017, 09:20 AM
RE: Philco 60 tuning shaft slips - by morzh - 01-10-2017, 09:23 AM
46-1201 Trip Switch Spring
So, Q1. Does anyone know where to get the spider. Q2. If there is no such place, what material is best? I doubt tin is...morzh — 09:43 PM
Arran The oxidation seems to go deep, a few layers. The break starts right there, but then it will occur on every la...morzh — 07:35 PM
