Philco Model 41-296X with 41-285 modified chassis
I am in such a quandry at this point, I have alot of money in this set to just quit, yet money is real tight right now, what to do.
Is it possible to check resistance on the Transformer in circuit? If so the readings on the main transformer are pretty close to the schematic, (schematic #'s in parenthesis) between the green and green on one side is 160 (160) the other is 110 (150).
Between the blacks is 4 (less 1) between the whites in 18 (12)
The field transformer, located next to the main transformer bottom? 300 (1100) this is the biggest difference. Does this tell me any thing? I would assume from this the field transformer is bad also Icon_confused:
Re: Philco Model 41-296X with 41-285 modified chassis - by jjbuzard - 12-01-2009, 11:52 AM
Philco 89 indicator light.
There are currently 4415 online users. [Complete List]
» 1 Member(s) | 4414 Guest(s)
