A Philco 91 restore
If you want to fix your old switch, pre war National Co communications receivers used a similar set up for their off,on, the stby switch. It used two toggle switches one just past the other. When faced w/a bad switch I used a generic bat switch. Shortened the bat and cut a notch into the leaver for the pin to actuate it. Worked fine.
Would be a lot easier to replace your with a switch w/one from a 70 or so...
A Philco 91 restore - by klondike98 - 01-10-2017, 02:36 PM
RE: A Philco 91 restore - by sam - 01-10-2017, 02:57 PM
RE: A Philco 91 restore - by morzh - 01-10-2017, 03:09 PM
RE: A Philco 91 restore - by klondike98 - 01-10-2017, 03:48 PM
RE: A Philco 91 restore - by morzh - 01-10-2017, 04:49 PM
RE: A Philco 91 restore - by Radioroslyn - 01-11-2017, 12:55 AM
RE: A Philco 91 restore - by klondike98 - 01-11-2017, 09:08 AM
RE: A Philco 91 restore - by morzh - 01-11-2017, 01:20 PM
RE: A Philco 91 restore - by Ron Ramirez - 01-11-2017, 01:21 PM
RE: A Philco 91 restore - by morzh - 01-11-2017, 01:25 PM
RE: A Philco 91 restore - by klondike98 - 01-11-2017, 05:55 PM
RE: A Philco 91 restore - by Nathan Slingerland - 01-11-2017, 06:14 PM
RE: A Philco 91 restore - by klondike98 - 01-11-2017, 06:16 PM
RE: A Philco 91 restore - by klondike98 - 01-12-2017, 01:11 PM
RE: A Philco 91 restore - by Ron Ramirez - 01-12-2017, 01:20 PM
RE: A Philco 91 restore - by Radioroslyn - 01-12-2017, 01:45 PM
RE: A Philco 91 restore - by klondike98 - 01-12-2017, 02:12 PM
RE: A Philco 91 restore - by Mondial - 01-12-2017, 06:18 PM
RE: A Philco 91 restore - by klondike98 - 01-12-2017, 08:42 PM
RE: A Philco 91 restore - by klondike98 - 11-13-2017, 05:09 PM
RE: A Philco 91 restore - by Steve Davis - 11-13-2017, 05:56 PM
RE: A Philco 91 restore - by Radioroslyn - 11-13-2017, 07:04 PM
RE: A Philco 91 restore - by klondike98 - 11-13-2017, 08:12 PM
RE: A Philco 91 restore - by klondike98 - 11-16-2017, 04:15 PM
RE: A Philco 91 restore - by klondike98 - 11-09-2018, 05:02 PM
RE: A Philco 91 restore - by klondike98 - 11-11-2018, 06:50 PM
RE: A Philco 91 restore - by Ron Ramirez - 11-12-2018, 12:23 AM
RE: A Philco 91 restore - by klondike98 - 11-12-2018, 08:35 AM
91H Code 126 Restore
