Model 42-380 with push button tuning
Ron,
Thanks for your input. The unit will not be playing when it is first plugged in even though I know it is on station. When I push in the broadcast button the sound will come in for a short while and then back out. The sound does not stay on permanently until the set has been warmed up for 10 minutes or longer. I replaced all the caps when i repaired the set but I don't remember whether they were mica or not for those you mentioned.
As far as cleaning, what is the best solution to use on this type of set?
Thanks
Model 42-380 with push button tuning - by Guest - 12-01-2009, 05:35 PM
Re: Model 42-380 with push button tuning - by Guest - 12-02-2009, 12:37 PM
Eico 232 VTVM Schematic
There are currently 5068 online users. [Complete List]
» 1 Member(s) | 5067 Guest(s)
