Wood Type Used
I think it was French walnut in particular, what cut doesn't matter. The grilles used in the 1928-29 "Lowboy" style console cabinets are almost as notorious for breakage as the Philco 20 cathedrals are. I think that the solution is to acquire some Baltic birch plywood of a suitable thickness, and then laminate it with some French walnut veneer, and then cut it out. Although if might be easier to check with Steve Davis about this, it's such a common problem that he may be replicating replacement grilles for these by now.
Wood Type Used - by PhilcoPhan1936 - 01-18-2017, 04:37 PM
RE: Wood Type Used - by Fred Taylor - 01-18-2017, 09:10 PM
RE: Wood Type Used - by Arran - 01-19-2017, 04:59 AM
RE: Wood Type Used - by Phlogiston - 01-19-2017, 01:13 PM
RE: Wood Type Used - by Phlogiston - 01-19-2017, 01:43 PM
RE: Wood Type Used - by sam - 01-19-2017, 02:18 PM
RE: Wood Type Used - by Phlogiston - 01-19-2017, 05:06 PM
RE: Wood Type Used - by PhilcoPhan1936 - 01-27-2017, 10:17 PM
RE: Wood Type Used - by OldRestorer - 01-28-2017, 12:09 AM
RE: Wood Type Used - by Ron Ramirez - 01-28-2017, 10:00 AM
RE: Wood Type Used - by PhilcoPhan1936 - 12-03-2017, 04:07 AM
RE: Wood Type Used - by PhilcoPhan1936 - 12-03-2017, 04:09 AM
RE: Wood Type Used - by PhilcoPhan1936 - 12-03-2017, 04:18 AM
RE: Wood Type Used - by Electrothaumaturgist - 12-03-2017, 02:43 PM
RE: Wood Type Used - by Phlogiston - 12-11-2017, 04:44 PM
RE: Wood Type Used - by Kenneth F. Besso Jr. - 12-11-2017, 06:36 PM
RE: Wood Type Used - by Arran - 12-12-2017, 04:41 PM
